How to support lvds for imx8m mini for Android
2,958 次查看
Ruban1
How to support lvds for imx8m mini for Android from MIPI dsi out.
7 回复数
2,949 次查看
joanxie
2,947 次查看
Ruban1
In that he is mentioned NXP doesnot support ffor BSP .
2,940 次查看
joanxie
yes, imx8mm doesn't have lvds interface, only imx8qm, imx8qxp and imx8mp have, if you want to use lvds display on the imx8mm, you need use the convert chip
2,937 次查看
Ruban1
Can you suggest me that convert chip details and is any drivers required to be build to support lvds for imx8m mini evk board
2,927 次查看
joanxie
we don't have official support chip, but another customer use SN65DSI84 to support lvds display successfully
2,886 次查看
Ruban1
is it necessary to create any additional drivers to support the chip. Or its just plug and play . If required any additional drivers can you suggest recommended documents to create Drivers.
2,876 次查看
joanxie
you need driver and dts file settings for this, pls refer to the topic, other customer porting it successfully and share their driver and dts file, you can refer to it:
"https://community.nxp.com/t5/i-MX-Processors/Adding-LVDS-Bridge-sn65dsi84-to-iMX8mm/m-p/1176287/high..."
