How to support LVDS in Uboot for imx8mm in Android OS
1,124件の閲覧回数
Ruban1
How to support LVDS in Uboot for imx8mm in Android OS.
Kindly provide the required Documents to Support , config , enable LVDS in Uboot .
Adding of new driver to detect the new driver what is the procedure in Uboot.
How to disable default driver in Uboot
For example default HDMI driver adv7535 how to disable it not to find when Uboot is starting
how to add or edit the Default driver setting in Uboot
Thanks and regards
Ruban
1,107件の閲覧回数
Juan-Rodarte
I noticed that you have opened other threads that are related to the same problem, if possible I would like to keep communication in one thread so we can avoid any misunderstanding.
https://community.nxp.com/t5/i-MX-Processors/U-boot-error-In-IMX8M-MINI-EVK-for-Android-10-OS/td-p/1...
Diego.
