How to solve libunwind-1.6.2-r0 do_compile: oe_runmake failed that appears when compiling with yocto
xueyf
I used the IMX8MP platform and pulled the yocto project from https://github.com/nxp-imx/imx-manifest/tree/imx-linux-langdale. The following is my compilation command
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-langdale -m imx-6.1.1-1.0.0_desktop.xml
repo sync
DISTRO=imx-desktop-xwayland MACHINE=imx8mpevk source imx-setup-desktop.sh -b build-desktop
bitbake imx-image-desktop
But the following error occurred,As a result, compilation fails. How should I solve this problem?
Harvey021
Suggest to check configuration for system source, cores and ram ...etc, on your build host.
and check the Host setup for packages updated on host. IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
Harvey
