How to show a frame rate of h.264 decoder output with gstreamer?
2,075 次查看
t-iishii
I hope to know a frame rate as h.264 decode result.
Can I get a result of the decoder output frame rate using gstreamer?
If no, please teach me some method to show a frame rate of h.264 decoder result.
Ishii.
标签 (4)
4 回复数
1,850 次查看
joanxie
you can find out from log file when you decoding the file, the log file would shows the time and frame number, then you can calculate it.
1,850 次查看
t-iishii
Hello Xie,
Thank you for your quick response.
As you say, that log file mean to use "GST_DEBUG" and "GST_DEBUG_FILE" option?
If so, which number for GST_DEBUG option will be output the time and frame number?
Ishii.
1,850 次查看
joanxie
you just need to play the video using unit test or gstreamer, you can find it.
1,850 次查看
t-iishii
Hello Joan,
Thank you for your response.
I was able to see it by playing the stream to the end.
Before it, I force stopped it because play time too long.
Ishii.
