SAIx_MCLK doesn't belong to one of the signals of SAIx IP inside CPU. It only provides a fixed 24MHz clock for external audio codec.
The 24MHz clock will be connected to MCLK pin of audio codec , to be it's work main clock.
According to your purpose, it seems that you want to generate bitclock, which should be generated by SAI1_BCLK of SAI1 IP, the bitclock's parent source is PLL.
Have a good day!
weidong
