I am trying to use i.MX 8M with DDR4.
The DDR4 under consideration to use is as follows.
We are going to have a total of 16Gb configuration by installing two.(8Gb x 2)
H5AN8G6NCJR-VKC(96ball)
:https://www.skhynix.com/products.view.do?vseq=2661&cseq=73
MX8M DDR4 RPA is using the latest version v11.
The DDR4 I am going to use has a 512Mb x 16 configuration.
However, RPA can be set from at least 2Gb.
Am I misunderstanding the usage of MX8M DDR4 Tool?
Or maybe the MX8M DDR4 Tool needs to be updated?
Kwon
EDIT1.
Is it right to do this??
已解决! 转到解答。
Your tool is the newest. Yes, you can configure it , refer to https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/iMX-8M-Mini-Register-Programming-Aid-DRA...
