Hi, everybody!
I change below:
--- a/arch/arm/boot/dts/imx6qdl-sabresd.dtsi
+++ b/arch/arm/boot/dts/imx6qdl-sabresd.dtsi
@@ -111,8 +111,8 @@
"IN3R", "MICBIAS",
"DMIC", "MICBIAS",
"DMICDAT", "DMIC";
- mux-int-port = <2>;
- mux-ext-port = <3>;
+ mux-int-port = <3>;
+ mux-ext-port = <2>;
backlight {
diff --git a/sound/soc/fsl/imx-wm8962.c b/sound/soc/fsl/imx-wm8962.c
index 3a3d17c..09ea6a5 100644
--- a/sound/soc/fsl/imx-wm8962.c
+++ b/sound/soc/fsl/imx-wm8962.c
@@ -247,7 +247,7 @@ static int imx_wm8962_probe(struct platform_device *pdev)
data->dai.platform_of_node = ssi_np;
data->dai.ops = &imx_hifi_ops;
data->dai.dai_fmt = SND_SOC_DAIFMT_I2S | SND_SOC_DAIFMT_NB_NF |
- SND_SOC_DAIFMT_CBM_CFM;
+ SND_SOC_DAIFMT_CBS_CFS;
data->card.dev = &pdev->dev;
ret = snd_soc_of_parse_card_name(&data->card, "model");
Please help me to config i2s master output bitclock 2.8Mhz lrclk 44.1kh.
Thank you and good luck to you!
