HI,all
I found that imx6 some gpio default is output high level once power on.
example:GPIO_2(GPIO_1_2)),NANDF_D5(GPIO_2_5)
My custom imx6dl board is used these two gpio to control lcd power and lcd reset.
These two gpio are default high level.
If I want these two gpio are default low level,what should I do?
Who can give me a help? Or give me an advices?
Leo
解決済! 解決策の投稿を見る。
Hi Leo
if one uses plugin mode, this can be added to dcd header.
Otherwise, for uboot 2009 this may be lowlevel_init.S,
for later uboot versions seems in miscellaneous functions
like board_xx_init_yy in ..freescale/mx6sabresd/mx6sabresd.c
Hi Leo
Hi igorpadyov,
I have added to uboot 2009 in lowlevel_init.S( lowlevel_init below,befor inv_dcache).
But it will have a very shorter time high level then (in lowlevel_init.S set to low level) low level once power on.
Leo
Hi Leo
default pad state after reset is not possible to change, so
there always will be short time until software change pin state.
This is inevitable.
~igor
