How to set display rotation at the boot of linux in iMX28?
memphis
I'm trying to use the iMX28 module in order to rotate the screen of 180 degrees, but how can I set the display to be rotated at the machine boot?
Regards.
GraceH
Senior Contributor II
MX28 doesn't support display rotation now. You can use PXP to implement rotation.
Grace
memphis
Thank you for you reply Grace, how I can use the PXP to implement rotation? Can you show me a guide to follow? Thank you a Lot
SergioSolis
Please take a look at this thread, it might be useful:
Re: i.MX23 CPU - Display Rotate function not working
GraceH
We don't have sample code to rotate frame buffer in MX28.
Grace
