How to set SD clock in I.MX6
1,458件の閲覧回数
bpmmaster
   Because some SDIO devices clock are  below 50MHz , Not as IMX51/53,  we can set the Max SD clock in board file.
In I.MX6 , there is no Max. Clock setting for SDIO.
   please help.
ラベル(5)
2 返答(返信)
1,197件の閲覧回数
igorpadykov
Yes, correct for i.MX6  there is no max. clock settings because
every ARM sub-arch has a different, incompatible struct clk implementation.
Seems you can add such max. restriction in function  _clk_usdhc_round_rate
(clock.c  file).
More about Linux clock architecture one can find on eLinux.org:
"Common clock framework: how to use it" - eLinux.org
1,197件の閲覧回数
bpmmaster
thanks
