How to set MX6Q-SDB board boot mode to serial download sicence it has no bootmode pins
JunqiYu
How to set the boot mode for the MCIMX6Q-SDB board(https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/sabre-board-for...)?Its Boot mode0 pin and Boot mode1 pin has not provided for user to set. Now I encountered the  problem(LIBUSB_ERROR_IO) while burning the MCIMX6Q-SDB board .
Labels (2)
Tags (2)
JunqiYu
Thank you for your detailed and patient answer,Thanks!
JunqiYu
Thank u for your response rapidly.That's useful.
Another question:
What need to do to the SD card first If I burn the SD card?For example, does it need to be formatted into a specific format, and does it require partitioning?
With the same question,What need I  do If I burn EMMC ?
Zhiming_Liu
