How to set DDR frequency to 400MHz on imx6Q
Search instead for
Hi :
  The imx6q DDR frequency is 528Mhz. I want to set DDR to run on 400MHz , how to modify the uboot config file mx6q_4x_mt41j128.cfg, or I should modify another file.    I use the fsl android sdk imx6q-N7.1.1-1.0.0.
  Thanks very much.
Hi yonglai
one can try solutions provided on
How to change DDR3 clock speed in U-boot/U-boot SPL?
https://community.nxp.com/thread/306143
Hi igorpadykov:
    Thanks for your reply,  I modified the plugin.S file as follows, but it did not work,  am I right? Thanks very much.
#elif defined (CONFIG_MX6Q)
    /*imx6dqsabresd_ddr_settting*/
    imx6dlsabresd_ddr_setting
#else
    #error "SOC not configured"
#endif
