How to run uuu for automatially setting environment variables?
2,467件の閲覧回数
jupiter_hce
Is there anyway to run uuu on customized imx6evk to set up multiple environment variables and run bootcmd automatically without manual set up in u-boot?
Thank you.
Kind regards,
- jupiter
ラベル(4)
タグ(1)
2,276件の閲覧回数
AldoG
You may try adding to your custom script the following
FB: ucmd setenv
FB: ucmd savenv
Also, it may be useful to take a look here:
https://github.com/NXPmicro/mfgtools/issues/84
Issues · NXPmicro/mfgtools · GitHub
Hope this helps,
Aldo.
