How to run the inference program with GPU on im8dxp board?
comx
I want to run the sample program for tensorflow-lite inference using GPU on the "imx8dxp" board, but I can't run it because there is no libvx_delegate.so in /usr/lib. Could you please tell me how I can run the inference sample program by running the GPU?
I tried to run the program with the following command, but could not.
python3 label_image.py --ext_delegate /usr/lib/libvx_delegate.so
joanxie
you can refer to the chapter 3 TensorFlow Lite to get detailed usage and build steps on imx8qxp board
joanxie
what image do you use? do you use prebuilt image or your own built image? did you refer to this user guide?
https://www.nxp.com.cn/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf
comx
Hello, joanxie
I'm sorry it took so long to get back to you.
I use my own built image.
I refer to imx-machine-learning-ug.pdf
I am a technical amateur in this field so it may take me a while to answer.
