How to run mxc_v4l2_capture.out ?
2,537件の閲覧回数
hanseunglee
In my case just use CSI0 OV5642 CAMERA. Not use MIPI.
root@freescale /unit_tests$ ./mxc_v4l2_capture.out -ow 1024 -oh 768
slave not found!
g_display_width = 1024, g_display_height = 768
g_display_top = 0, g_display_left = 0
Unable to open /dev/video0
Maybe use bt656 mode in mxc_v4l2_capture.c.
If i want to change gated mode, how to change source?
hot to solve error and then change interface bt656 -> gated mode ?
ラベル(2)
1,584件の閲覧回数
Hi Hanseung
gated mode is not supported by default in BSP, for its usage one can look at
How to Support RGB565 Gated Mode Input to i.MX6 CSI
1,585件の閲覧回数
Hi Hanseung
