Hi community:
When dual screen display, QT always runs on the screen with weston desktop , how to make it run on another screen.
Please provide a method for me to test.
Hello coin,
I just reproduce the required test and did not face any issue. Please, check the attached video.
As you can see (sorry for the focus), the i.MX 8MQ EVK is running two Qt5_Cinematics example at 60fps, consuming about 42% of CPU each one and 850MB of RAM.
Hi Bio_TICFSL,How to run two QT APP on the IMX8MQ-EVK board and display them on the different displays.If you load demo video and image, could you update it to the baidu disk? Otherwise, we can't get them.Looking forward to your reply. Thank you!
Hi:
Please provide the test method.
Thanks for your reply.
You may have uploaded a video, but it cannot be loaded here. Can you provide test examples and test methods?
