How to run an app on key Press?
1,190 次查看
danix
Hey all,
I've a custom board with imx233, pretty much the same as the EVK. I've four push buttons in a ladder connected to the LRADC channel0.
I just want to run some application when a key is pressed, but I'm not sure how to do that, Where exactly is the interrupt service routine?
Similarly, pressing any key can wake my device from suspend... and again I want to launch an application when the system wakes up
This may be a silly question, but I don't know how, somebody guide me on the how to (details are appreciated)
Thanks in advance
标记 (1)
2 回复数
1,094 次查看
danix
Hi Daiane,
I don know either, but I'll try it
Sure, I'm hoping someone has a better idea.... I'm waiting
Thanks!
1,093 次查看
daiane_angolini
I think you can use udev for that. But I don´t know the right configuration way.
Let´s see if someone else has a better idea
