How to reset DRAM_RESET pin go to Low level?
1,945 次查看
takayuki_ishii
Hello community,
I checking a function around MMDC of i.MX6QP.
After initialized DRAM(MDCTL[SDE_x]=1 and DRAM_RESET goed Hi and DRAM_SDCKE start working.),
Does it have some method to DRAM_RESET go to Low level?
If MDCTL[SDE_x] = 0, DRAM_SDCKE was stopping, but DRAM_RESET keep to Hi level.
If MDMISC[RST] = 1, asserted reset to MMDC, but DRAM_RESET keep to Hi level.
Does MDCTL[SDE_x] bit only perform to DRAM_RESET from low to hi level in initialization process?
To clear MMDC configuration/status registers and DRAM_RESET pin level, it must need Hard Reset?
Ishii.
标签 (2)
1,857 次查看
Hi Ishii
right.
yes. It is necessary to follow sequence described in sect. 46.4.2 MMDC initialization
i.MX 6DualPlus/6QuadPlus Applications Processor Reference Manual
1,858 次查看
Hi Ishii
right.
1,857 次查看
takayuki_ishii
Hello Igor,
Thank you for your quick response.
I recheck MDCTL[SDE_x] bit function based on this information.
Ishii.
