Hi,all
I have an imx6q motherboard, when using MicroSD card, the linux always prompts SD card for read-only mode, how can I solve this problem?PS:linux BSP 4.1.15
Solved! Go to Solution.
Do you boot with a device tree ? How is set the SD-card node ?
You can add 'disable-wp;' to the node to allow writing accesses.
Hi,Quentin
thanks for your advice, I will try it
By the way,the MicroSD can be written and read in Win 10 By adapter,and without adapter in linux 4.1.1.5,It's can only be read
