Thank you for your reply, I disabled the 32K output already, also disabled the SRTC power supply (by resetting DRM bit). Now I even disable MC13892 RTC by setting RTCDIS bit, the current is still high.
Can you help me to check which regulators or other modules can consume the power from backup battery?
My board is designed following the ref board. I am trying to compare the differences, can you give me some specific tips? Thanks again.
