How to record mono audio using i.MX8M Quad EVK
Hello Abhishek,
Xiaocong is rigth.
Hi Abhishek,
The codec in i.MX8MQ evk board is WM8524, which is a DAC and only supports audio playback. If you want to record audio using i.MX8MQ evk board, you need to connect mic via SAI interface and create driver for it.
Xiaocong
