I want to read MJPEG format on i.MX RT1176 source from camera.
Could you tell me how to read MJPEG format on i.MX RT1176 or this IC cannot read this format.
Thanks.
Solved! Go to Solution.
Hi @scarletlee ,
There isn't examples of read mjpeg from camera. In SDK, libjpeg source code is provided, customer only need to do it according to AN12110.pdf. You can see the USB virtual camera example use mjpeg format.
Jing
did you find how to do this ? i am really interested.
Safouane.Maaloul
Hi @scarletlee ,
Jing
