How to promote memory copy rate between FPGA and IMX8MQ?
1,987件の閲覧回数
mimi05633
Hi NXP team,
My topology: FPGA ---(pcie access by mmap dev/mem)--- ARM(malloc buffer)
After our program did memory copy(copy from FPGA to IMX8MQ) by memcpy API, the rate was only 5MB/s.
I also use neon memcpy method to promote memory copy rate(about 11MB/s).
According to https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX6Q-PCIe-EP-RC-Validation-System/ta-p...,
all memory copy results are better than my test result.
And I find that memory copy of cached PCIe is better than uncached PCIe, and memory copy with IPU DMA is the best performance.
Do I need change uncached PCIe to cached PCIe? If yes, how can I do?
How can I use IPU DMA on IMX8MQ? Is there any sample code for IMX8MQ?
I appreciate if someone can help me to solve it.
Thank you for any help.
Minying
タグ(2)
3 返答(返信)
1,970件の閲覧回数
igorpadykov
Hi Minying
for PCIe performance analysis one can look at AN13164  iMX8MP PCIe Bandwith Analysis
https://www.kernel.org/doc/html/latest/PCI/endpoint/pci-test-howto.html
1,949件の閲覧回数
mimi05633
Hi Igor,
I am sorry to late reply. Thank you for your response.
I am new to PCIe. I want to promote PCIe's speed on the IMX8MQ(RC mode).
After I research promoted method, there are some promoted methods by DMA.
Does IMX8MQ support DMA implemented on PCIe RC mode? If Yes, how can I do?
Is "Throughput results" section base on IMX8MQ(RC) side on URL https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX6Q-PCIe-EP-RC-Validation-System/ta-p...?
Update my topology: IMX8MQ(RC) ---(pcie)--- FPGA(EP)
Minying
1,937件の閲覧回数
igorpadykov
