How to program DTB file only for SABRE board?
ソリューションへジャンプ
3,502件の閲覧回数
Sun1z
Is it possible to use mfgtool to program/update DTB file only to i.MX6Q SABRE board (Android M6.0.1_2.1.0 GA)?
B.R.
Sun
ラベル(2)
2,558件の閲覧回数
JayTu
The device tree is part of the boot.img. You can unpack the boot.img and re-pack it with your device tree.
4 返答(返信)
2,559件の閲覧回数
JayTu
2,558件の閲覧回数
Sun1z
Got it clear that even there is a minor modification only in dts file, I need re-program the boot.img again.
2,558件の閲覧回数
Sun1z
I checked ucl2.xml and found for eMMC-Android, no DTB file is involved, means for android, no DTB required? then how I can set the device tree.
2,558件の閲覧回数
joanxie
if you need to build kernel, you need to use toolchian, mfgtools is for download image to your board,you can refer to the document as below:
Task #8 - Build kernel manually using created toolchain
for path, you can find the dts file under:
fsl-release-bsp/build/tmp/work-shared/imx6qsabresd/kernel-source/arch/arm/boot/dts
