How to porting FEC driver(rtl8306e) to imx8mq
3,102 次查看
951107618
HI all:
 I was porting rtl8306e driver to imx8mq android, and I am new to this, is there some documents and samples about it , Thanks.
标记 (2)
4 回复数
2,721 次查看
951107618
hi all,
I look into the fec_main.c code  and  some documents, I found the fec_main.c is about Motorola MPC8xx driver, I shoud write a new file for rtl8306e, Now I confused how to write  "_probe"  function , Is there some sample for it?
2,721 次查看
951107618
HI igor:
Thanks for your reply, the document you provided is very useful for me , but I was too Embarrassed  to say that I was very new to freesclae platform and ethernet driver, I don't know how to start following three steps,and I download rtl8306e_asicdrv files in attchement rtl8306.rar.
• Pin configuration
• Source code
   I modify code in fec_main.c, but I don,t know where rtk_switch_init should be add.
• Ethernet connection configuration
So, is there some example exist that can be referenced ,  other related drivers are also available.
Thanks very much.
Chris
2,721 次查看
Hi Chris
please look at description of Linux drivers included in documentation packages on
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
2,720 次查看
Hi Chris
please refer to attached Porting Guide, first try to make
rtl8306e functional in uboot, then in linux with minimal configuration.
