How to play custom audio with Pico TFA98XX
Showing results forย
Search instead forย
Did you mean:ย
running_gao
Thanks for reviewing my questions. We have a trouble using TFA 98XX UK SDK, the Pico TFA98XX Evaluation Software. Our purpose is to import and play some custom .mp3 sounds at first place. It seems that the sound file could be played by Pico is .speaker file (from โ€˜File-Open-dropdown listโ€™), is there a way to open a .mp3 file by the SDK? Thanks.
Tags (2)
CarlosCasillas
If you are using a PICO platform, you would need to directly contact with Technexion support, as they are the owners of the BSP and may provide the proper guidelines about the supported features.
Please refer to the following link:
https://www.technexion.com/support/
Hope this will be useful for you.
Best regards!
/Carlos
