How to pass the environment variables set in u-boot to a driver?
已解决
跳至解决方案
1,584 次查看
logic887
On the i.MX8MP platform, with Linux 6.1, after setting environment variables using setenv in u-boot, how to pass these parameters to a driver?
1 解答
1,565 次查看
Dhruvit
Hi @logic887,
I hope you are doing well.
Could you please elaborate more about the use case?
Are you referring to U-boot drivers or Kernel Drivers?
One can edit bootargs env to edit kernel cmdline.
=> setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot} <module_name>.<parameter_name>=value  '
It will automatically pass kernel parameters to the driver.
Thanks & Regards,
Dhruvit Vasavada
在原帖中查看解决方案
2 回复数
1,566 次查看
Dhruvit
Hi @logic887,
Thanks & Regards,
Dhruvit Vasavada
1,537 次查看
logic887
You're welcome, the issue has been resolved.
