How to overlay 2 cameras on same screen at same time on I.MX6Q?
ct3paul
     ALL
     Now,I want to use overlay to make 2 cameras display on same screen at same time .
     MY BSP: LINUX3.0.35
     MY BOARD:IMX6Q_sabresd
     I want use fsl's code /test/mxc_v4l2_overlay.c,but I can't achieve 2 cameras display at same screen.
     Is there anybody do the same things or can somebody can help me ?
Thanks!
chen
saurabh206
Senior Contributor III
Hi Chen
check following.
I hope this helps you.
https://community.freescale.com/docs/DOC-102133
Saurabh
ct3paul
Hi Saurabh
     My BSP is linux-3.0.35,but this is linux-3.10.17.
     I cat't do it like   /unit_tests/mxc_v4l2_overlay.out -t 200 -di /dev/video19 & /unit_tests/mxc_v4l2_overlay.out -t 200 -fg -ot 200 -ol 200 -di /dev/video20 &
     I got a error.
Thanks!
Chen
saurabh206
Hi Tao
Are you using LTIB or Yocto for your BSP?
LTIB also has similar test.
Saurabh
