How to modify the UUU download USB port of imx8qxp
relax-wu
SDK:Android Q10.0.0_2.2.0_AUTO
Currently using USB3.0 by default, now I want to change to another usb2.0 port。
Rita_Wang
I will try  it on my board this week and then tell you the result.
Rita_Wang
Do you mean you use the usb otg port in the base board?
relax-wu
yes
Rita_Wang
The download method is the same, here you need to connect the USB OTG port firstly. If it can not work contact us.
relax-wu
My test failed.
Stuck here:
Rita_Wang
which version android BSP are you using? And are you using the i.MX8QXP C0 version board?
relax-wu
I used the development board B0 to test.
https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/i-mx-8quadxplus...
