How to make jpegs with hardware acceleration
sl2
Hi NXP community,
i am using a MX8MQEVK Developer Board and i want to make jpegs from yuyv Buffer with hardware support.
So i tried encoder_test from the unit tests and this is not working yet. Which dev node should i use?
Isn't it also possible to use VPU with vpu_wrapper? And where is the libfile located?
Many thanks in advance...
Daniel Grünewald
Bio_TICFSL
Hello Daniel,
For encoder supported only VP8 and H.264 as described in Table Supported Standards,
Profiles and Levels i.MX8M Reference Manual.
