How to keep config for 3.14.28 kernel together with 3.14.28.bb?
yanfengliu
We can use "bitbake linux-imx -c menuconfig" to customize the 3.14.28 kernel configuration.
However, we can't persist the customized configuration by following the Building Linux Kernel link, reason is 3.14.28.bb kernel recipe doesn't take defconfig saved under the folds mentioned in that guide since it contains the following line:
{code}
do_configure_prepend() {
   # copy latest defconfig for imx_v7_defoonfig to use
   cp ${S}/arch/arm/configs/imx_v7_defconfig ${S}/.config
   cp ${S}/arch/arm/configs/imx_v7_defconfig ${S}/../defconfig
{code}
Can we modify the 3.14.28.bb somehow to use a defconfig in a folder similar to the one mentioned in Building Linux Kernel​?
yanfeng
Labels (3)
jamesbone
You need to do the following:
linux-imx_3.14.28.bb
# copy latest defconfig for imx_v7_defconfig  to use
fi
Please see more details in the following threads
Kernel config file used by Yocto
Changing the Kernel configuration for i.MX6 SABRE
