How to interconnect i.MX8MM with FPGA
已解决
跳至解决方案
3,651 次查看
chao
Hello, everyone, I am developing a project using i.MX8MM. FPGA is required as an external memory device in the project, and Nandflash is also necessary.I read the entire manual carefully, and it seems that I did not find an EIM interface suitable for connecting to FPGA.Is there a good solution to this problem?
标签 (1)
标记 (2)
1 解答
3,638 次查看
Hi liaochao
one can consider other standard interfaces like flexspi, pcie, ecspi.
在原帖中查看解决方案
3 回复数
3,622 次查看
chao
Thank you @igorpadykov  for the reply,
We have already used PCIe on other modules, so the PCIe interface cannot be used. In addition, ecspi cannot meet the communication bandwidth requirements.So flexspi may be the best choiAce.
According to i.MX 8M Mini Applications Processor Reference Manual, Rev. 2, 08/2019, we did not find the specific details of how to communicate with FPGA. Do you have any application cases or  the information can be referenced.
3,619 次查看
for FlexSPI usage one can look at i.MXRT resources (it has the same module)
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-...
3,639 次查看
Hi liaochao
