How to install & verify lpcscrypt in Ubuntu?
1,280 次查看
GanesanGuru
Hi fellas,
I've downloaded LPCScrypt v2.1.2 as lpcscrypt-2.1.2_57.x86_64.deb.bin and run with root privileges, yet I'm not sure where it has installed or how to access it further.. During installation, it happened as follows:
标记 (3)
1,263 次查看
Rita_Wang
Which product are you using?
1,258 次查看
GanesanGuru
Hi  @Rita_Wang   ,
I'm using iMX RT1064-EVK board and in order to re-program the onboard debugger LPC4322 using  AN13206 , I'm in need of the lpcsrypt . I'm installing those in Ubuntu OS and while installing I'm facing the issues mentioned above..
PS : I'm doing so, to program a custom board KM34 via this onboard debugger using LPC4322 MCU
1,255 次查看
Rita_Wang
I create new case 00572365 to our RT engineer, she will give update to you then you will receive the email.
