How to get zImage and rootfs loaded onto qspi-nor
1,113件の閲覧回数
rja
In several tickets (below) we found that the ucl2.xml file is not actually writing the rootfs (fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot), the zImage or the .dtb file to the qspi-nor. How do we edit the file in order to load our very small and custom rootfs and zImage to this device? Also, do we need to edit the qspi-nor header in order to get it recognized?
How do imx6ul-evk boot from QSPI?
https://community.nxp.com/thread/479465
ラベル(2)
948件の閲覧回数
gusarambula
Hello Ryan Arndorferm,
Are you still experiencing problems? There are some scripts on the manufacturing tool with the parameters to load different boot sources and some versions of the manufacturing tool also have a qsp-nor .vbs file for some boards (the i.MX6UL EVK should be included). Alternatively, the new UUU (Universal Update Utility) is a bit more flexible so you may also want to look at it.
