How to get gpio value when I change it.
1,284件の閲覧回数
sijian_cai
In imx6ul , I use gpio 19 for test , if I make the dir to out , and then I echo 1 or 0 to value , I can get the correct status by multimeter , but how can I get the gpio value in the use space ? And may I read the register value ? Thanks a lot.
1,072件の閲覧回数
CarlosCasillas
An option could be using boolean variables for the pin values, and using those variables to assign the pin values and to know the pin status.
Additionally, you could find some complementary information at the link below:
Access GPIO from Linux user space
Hope this will be useful for you.
Best regards!
/Carlos
1,072件の閲覧回数
BiyongSUN
