How to get PTS from the H264 decoder Module ?
4,369 次查看
subodh
I am trying to write a sample media player on iMX6.
One of the primary objectives is to understand the synchronization between audio and video.
To accomplish this my application needs to get video PTS from decoder and the submit the corresponding
audio data to the AACPlus decoder API.
The VPU documentation does not mention any specifics about the timing information.
I am not sure but from what I understood, Gstreamer maintains its own clock and submits the data accordingly.
Please guide me on this front regarding AV synchronization.
Thanks in advance.
标签 (4)
3,821 次查看
3,821 次查看
Hi Subodh
you are correct VPU does not maintain audio synchro
it is done in gstreamer . Please check timestamping API
gstreamer documentation below
GStreamer: Documentation
http://gstreamer.freedesktop.org/data/doc/gstreamer/head/pwg/pwg.pdf
3,821 次查看
subodh
Hi Igor,
I want to write a native player around the vpu API, in that case what method would you suggest for AV Synchronization.
3,822 次查看
Hi Subodh
I think you can look below and choose what is suitable
http://en.wikipedia.org/wiki/Audio_to_video_synchronization#MPEG:_Presentation_Time_Stamp_.28PTS.29....
