How to generate PWM signal on iMX8ULP?
wendy-liu
Dear all,
    I found tpm5 device node in imx8ulp.dtsi, I enable it.
    I chose PTF19 (J20 pin3) to generate PWM signal.
   But I can't fing anything under sysfs,such as /sys/class/tpm or /sys/class/pwm/.I use oscilloscope to measure it waveform , and it keeps outputting a high-level signal.
   My dts ,config, log are as below.
    Hope your reply!Thanks a lot!
Best Regards!
Zhiming_Liu
Do you solve this issue? I see you have another case about other TPMs clock issue, the TPM clock is generated in ATF: plat/imx/imx8ulp/imx8ulp_bl31_setup.c
	/* config the TPM5 clock */
	mmio_write_32(IMX_PCC3_BASE + 0xd0, 0x92000000);
	mmio_write_32(IMX_PCC3_BASE + 0xd0, 0xd2000000);
Zhiming
wendy-liu
Hello!
Here are some updates  I'd like to share with you.
Fortunately, I enable TPM7 CH5(PTF25) successfully, but there is no output waveform.
my device node  :
+tpm7: tpm@29830000 {
+ //compatible = "fsl,imx8ulp-tpm", "fsl,imx7ulp-tpm";
+ compatible = "fsl,imx7ulp-pwm";
+ reg = <0x29830000 0x10000>;
+ //interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
+ clocks = <&pcc4 IMX8ULP_CLK_TPM7>, <&pcc4 IMX8ULP_CLK_TPM7>;
+ assigned-clocks = <&pcc4 IMX8ULP_CLK_TPM7>;
+ assigned-clock-parents = <&cgc1 IMX8ULP_CLK_FROSC_DIV2>;
+ //assigned-clock-rates = <48000000>;
+ //clock-names = "ipg", "per";
+ status = "okay";
+&tpm7 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_tpm7>;
+ #pwm-cells = <3>;
pinctrl_tpm7: tpm7grp {
                fsl,pins = <
                        MX8ULP_PAD_PTF25__TPM7_CH5      0x2
my commands :
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8# echo 5 > export
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8# cd pwm5/
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 400000 > period
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 200000 > duty_cycle
root@imx8ulp-lpddr4-evk:/sys/class/pwm/pwmchip8/pwm5# echo 1 > enable
Zhiming_Liu
Do you solve this issue? I just get notification from system, you can add more print in the pwm driver to check if the hardware status.
Zhiming
wendy-liu
yes, I have been solved! Thanks a lot!
wendy-liu
Could you test it on iMX8ULP-evk board?
Zhiming_Liu
Sure
wendy-liu
Looking forward to your reply!Thank you very much!
Best Regards!
Zhiming_Liu
Zhiming
wendy-liu
Hello , pwm signal of TPM5 CH0 is successfully generated!
Now , I'm facing another problem...I successfully enable pwm signal of TPM7 CH5(PTF25), but there is no output waveform
status = "okay";
&tpm7 {
#pwm-cells = <3>;
fsl,pins = <
Zhiming_Liu
The EVK dts also use tpm5 , can you try the 0x57e pinctrl value?
	pinctrl_tpm5: tpm5grp {
		fsl,pins = <
			MX93_PAD_GPIO_IO06__TPM5_CH0		0x57e
Zhiming
wendy-liu
@Zhiming_Liu
Thanks for your advice.I tried it, But it doesn't work.......
Zhiming_Liu
Please comment these two lines and try again.
cs-gpios = <&gpiof 19 GPIO_ACTIVE_LOW>;
MX8ULP_PAD_PTF19__PTF19 0x43
Zhiming
wendy-liu
@Zhiming_Liu
sorry, i did't see "these two lines".
Could you send me again? I will try it!
Zhiming_Liu
updated
wendy-liu
sorry, it also did't work
Zhiming_Liu
1. The default dtsi tpm node is using tpm timer driver and there is no pwm driver using tpm. That's why you can't see the /sys/class/pwm
2.To use pwm tpm driver, you need modify dtsi like this:
			tpm5: tpm@29340000 {
				reg = <0x29340000 0x1000>;
				// interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
				clocks = <&sosc>, <&sosc>;
				// clock-names = "ipg", "per";
				#pwm-cells = <3>;
				status = "okay";
3. I can see pwm  node after modifing it.
root@imx8ulpevk:/sys/class/pwm/pwmchip0/device/of_node# cat compatible
fsl,imx7ulp-pwmroot@imx8ulpevk:/sys/class/pwm/pwmchip0/device/of_node#
Zhiming
wendy-liu
wow, after modifying it, i can control duty_circle and period under sysfs.
But I measure it waveform , it still keeps outputting a high-level signal.
Zhiming_Liu
Where is your test point on evk?
Zhiming
wendy-liu
PTF19 (J20 pin3)
        fsl,pins = <
                 MX8ULP_PAD_PTF19__TPM5_CH0 0x19e
Zhiming_Liu
The signal from PTF19 is muxed to EPDC_D4 or PTF19_PTF19
Try to include below line in tpm5 node.
pinctrl-assert-gpios = <&pca6416_1 10 GPIO_ACTIVE_LOW>;
Zhiming
wendy-liu
Thanks for your helping!But it still doesn't work(T_T)
%3CLINGO-SUB%20id%3D%22lingo-sub-2051451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20all%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20I%20found%20tpm5%20device%20node%20in%26nbsp%3Bimx8ulp.dtsi%2C%20I%20enable%20it.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%3CSPAN%3EI%20chose%20PTF19%20(J20%20pin3)%20to%20generate%20PWM%20signal.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325436iD0A690FD1935ABF4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3BBut%20I%20can't%20fing%20anything%20under%20sysfs%2Csuch%20as%20%2Fsys%2Fclass%2Ftpm%20or%20%2Fsys%2Fclass%2Fpwm%2F.I%26nbsp%3Buse%20oscilloscope%20to%20measure%20it%20waveform%20%2C%20and%20it%20keeps%20outputting%20a%20high-level%20signal.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3BMy%20dts%20%2Cconfig%2C%20log%20are%20as%20below.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20Hope%20your%20reply!Thanks%20a%20lot!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20Regards!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2051451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eyes%2C%20I%20have%20been%20solved!%20Thanks%20a%20lot!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EDo%20you%20solve%20this%20issue%3F%20I%20just%20get%20notification%20from%20system%2C%20you%20can%20add%20more%20print%20in%20the%20pwm%20driver%20to%20check%20if%20the%20hardware%20status.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHello!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHere%20are%20some%20updates%26nbsp%3B%20I'd%20like%20to%20share%20with%20you.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFortunately%2C%20I%20enable%20TPM7%20CH5(PTF25)%20successfully%2C%20but%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ethere%20is%20no%20output%20waveform.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emy%20device%20node%26nbsp%3B%20%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Btpm7%3A%20tpm%4029830000%20%7B%3CBR%20%2F%3E%2B%20%2F%2Fcompatible%20%3D%20%22fsl%2Cimx8ulp-tpm%22%2C%20%22fsl%2Cimx7ulp-tpm%22%3B%3CBR%20%2F%3E%2B%20compatible%20%3D%20%22fsl%2Cimx7ulp-pwm%22%3B%3CBR%20%2F%3E%2B%20reg%20%3D%20%26lt%3B0x29830000%200x10000%26gt%3B%3B%3CBR%20%2F%3E%2B%20%2F%2Finterrupts%20%3D%20%3CGIC_SPI%2087%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3CBR%20%2F%3E%2B%20clocks%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%2C%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3E%2B%20assigned-clocks%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3E%2B%20assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bcgc1%20IMX8ULP_CLK_FROSC_DIV2%26gt%3B%3B%3CBR%20%2F%3E%2B%20%2F%2Fassigned-clock-rates%20%3D%20%26lt%3B48000000%26gt%3B%3B%3CBR%20%2F%3E%2B%20%2F%2Fclock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%3CBR%20%2F%3E%2B%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%2B%7D%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2B%26amp%3Btpm7%20%7B%3CBR%20%2F%3E%2B%20pinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3E%2B%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_tpm7%26gt%3B%3B%3CBR%20%2F%3E%2B%20%23pwm-cells%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%2B%7D%3B%3C%2FP%3E%3CDIV%3E%3CSPAN%3Epinctrl_tpm7%3A%20tpm7grp%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20fsl%2Cpins%20%3D%20%26lt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20MX8ULP_PAD_PTF25__TPM7_CH5%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%200x2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26gt%3B%3B%3C%2FDIV%3E%3CDIV%3E%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Emy%20commands%20%3A%3C%2FDIV%3E%3CDIV%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%23%20echo%205%20%26gt%3B%20export%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%23%20cd%20pwm5%2F%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20400000%20%26gt%3B%20period%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20200000%20%26gt%3B%20duty_cycle%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%201%20%26gt%3B%20enable%3CBR%20%2F%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%2C%20pwm%20signal%20of%20TPM5%20CH0%20is%20successfully%26nbsp%3Bgenerated!%3C%2FP%3E%3CP%3ENow%20%2C%20I'm%20facing%20another%20problem...I%26nbsp%3Bsuccessfully%20enable%26nbsp%3Bpwm%20signal%20of%20TPM7%20CH5(PTF25)%2C%20but%20%3CSPAN%3Ethere%20is%20no%20output%20waveform%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Etpm7%3A%20tpm%4029830000%20%7B%3CBR%20%2F%3E%2F%2Fcompatible%20%3D%20%22fsl%2Cimx8ulp-tpm%22%2C%20%22fsl%2Cimx7ulp-tpm%22%3B%3CBR%20%2F%3Ecompatible%20%3D%20%22fsl%2Cimx7ulp-pwm%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x29830000%200x10000%26gt%3B%3B%3CBR%20%2F%3E%2F%2Finterrupts%20%3D%20%3CGIC_SPI%2087%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3CBR%20%2F%3Eclocks%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%2C%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3Eassigned-clocks%20%3D%20%26lt%3B%26amp%3Bpcc4%20IMX8ULP_CLK_TPM7%26gt%3B%3B%3CBR%20%2F%3Eassigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bcgc1%20IMX8ULP_CLK_FROSC_DIV2%26gt%3B%3B%3CBR%20%2F%3E%2F%2Fassigned-clock-rates%20%3D%20%26lt%3B48000000%26gt%3B%3B%3CBR%20%2F%3E%2F%2Fclock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%3CBR%20%2F%3Estatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3Btpm7%20%7B%3CBR%20%2F%3Epinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_tpm7%26gt%3B%3B%3CBR%20%2F%3E%23pwm-cells%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epinctrl_tpm7%3A%20tpm7grp%20%7B%3CBR%20%2F%3Efsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3EMX8ULP_PAD_PTF25__TPM7_CH5%200x2%3CBR%20%2F%3E%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20400000%20%26gt%3B%20period%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%20200000%20%26gt%3B%20duty_cycle%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eroot%40imx8ulp-lpddr4-evk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip8%2Fpwm5%23%20echo%201%20%26gt%3B%20enable%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EDo%20you%20solve%20this%20issue%3F%20I%20see%20you%20have%20another%20case%20about%20other%20TPMs%20clock%20issue%2C%20the%20TPM%20clock%20is%20generated%20in%20ATF%3A%20plat%2Fimx%2Fimx8ulp%2Fimx8ulp_bl31_setup.c%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%09%2F*%20config%20the%20TPM5%20clock%20*%2F%0A%09mmio_write_32(IMX_PCC3_BASE%20%2B%200xd0%2C%200x92000000)%3B%0A%09mmio_write_32(IMX_PCC3_BASE%20%2B%200xd0%2C%200xd2000000)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELooking%20forward%20to%20your%20reply!Thank%20you%20very%20much!%3C%2FP%3E%3CP%3EBest%20Regards!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESure%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20test%20it%20on%20iMX8ULP-evk%20board%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20helping!But%20it%20still%20doesn't%20work(T_T)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20signal%20from%20PTF19%20is%20muxed%20to%20EPDC_D4%20or%20PTF19_PTF19%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditorZhiming_Liu_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image%20(1).png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325960i5E874731849471A6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(1).png%22%20alt%3D%22image%20(1).png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ETry%20to%20include%20below%20line%20in%20tpm5%20node.%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3Epinctrl-assert-gpios%20%3D%20%26lt%3B%26amp%3Bpca6416_1%2010%20GPIO_ACTIVE_LOW%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EPTF19%20(J20%20pin3)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epinctrl_tpm5%3A%20tpm5grp%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BMX8ULP_PAD_PTF19__TPM5_CH0%200x19e%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EWhere%20is%20your%20test%20point%20on%20evk%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ewow%2C%20after%20modifying%20it%2C%20i%20can%20control%20duty_circle%20and%20period%20under%20sysfs.%3C%2FP%3E%3CP%3E%3CSPAN%3EBut%20I%20measure%20it%20waveform%20%2C%20it%20still%20keeps%20outputting%20a%20high-level%20signal.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20The%20default%20dtsi%20tpm%20node%20is%20using%20tpm%20timer%20driver%20and%20there%20is%20no%20pwm%20driver%20using%20tpm.%20That's%20why%20you%20can't%20see%20the%20%2Fsys%2Fclass%2Fpwm%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.To%20use%20pwm%20tpm%20driver%2C%20you%20need%20modify%20dtsi%20like%20this%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%09%09%09tpm5%3A%20tpm%4029340000%20%7B%0A%09%09%09%09compatible%20%3D%20%22fsl%2Cimx7ulp-pwm%22%3B%0A%09%09%09%09reg%20%3D%20%26lt%3B0x29340000%200x1000%26gt%3B%3B%0A%09%09%09%09%2F%2F%20interrupts%20%3D%20%3CGIC_SPI%2087%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%0A%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bsosc%26gt%3B%2C%20%26lt%3B%26amp%3Bsosc%26gt%3B%3B%0A%09%09%09%09%2F%2F%20clock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%0A%09%09%09%09%23pwm-cells%20%3D%20%26lt%3B3%26gt%3B%3B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%3C%2FGIC_SPI%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E3.%20I%20can%20see%20pwm%26nbsp%3B%20node%20after%20modifing%20it.%3C%2FP%3E%0A%3CP%3Eroot%40imx8ulpevk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip0%2Fdevice%2Fof_node%23%20cat%20compatible%3CBR%20%2F%3Efsl%2Cimx7ulp-pwmroot%40imx8ulpevk%3A%2Fsys%2Fclass%2Fpwm%2Fpwmchip0%2Fdevice%2Fof_node%23%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Esorry%2C%20it%20also%20did't%20work%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eupdated%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Esorry%2C%20i%20did't%20see%20%22%3CSTRONG%3Ethese%20two%20lines%3C%2FSTRONG%3E%22.%3C%2FP%3E%3CP%3ECould%20you%20send%20me%20again%3F%20I%20will%20try%20it!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20comment%20these%20two%20lines%20and%20try%20again.%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorZhiming_Liu_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3Ecs-gpios%20%3D%20%26lt%3B%26amp%3Bgpiof%2019%20GPIO_ACTIVE_LOW%26gt%3B%3B%3C%2FP%3E%0A%3CP%3EMX8ULP_PAD_PTF19__PTF19%200x43%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EThanks%20for%20your%20advice.I%20tried%20it%2C%20But%20it%20doesn't%20work.......%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20generate%20PWM%20signal%20on%20iMX8ULP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20EVK%20dts%20also%20use%20tpm5%20%2C%20can%20you%20try%20the%26nbsp%3B%3CSPAN%3E0x57e%20pinctrl%20value%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%09pinctrl_tpm5%3A%20tpm5grp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX93_PAD_GPIO_IO06__TPM5_CH0%09%090x57e%0A%09%09%26gt%3B%3B%0A%09%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
