How to generate 3 different H.264 streams for 1 CSI stream ?
1,179件の閲覧回数
frederic_coiffi
We're looking for some advices about using GStreamer to generate several H.264 streams from one 720p 25fps CSI stream.
It's quite simple to generate one H.264 RTP stream for 1 CSI input.But we would like to generate 3 different H.264 streams, i.e. :
  • 1 x RTP H.264 720p 25fps
  • 1 x RTP H.264 800x600 25fps (resize + crop)
  • 1 x RTC H.264 720p 6fps (different framerate)
Do you think it's possible ? Can GStreamer use the IPU to generate 2 streams with different resolution ? As the VPU encodes 3 differents streams, it means 3 pipes for GStreamer and lot's of memory copy.
So, we would be interested if someone has already a feedback about a similar use case.
ラベル(5)
タグ(4)
1,036件の閲覧回数
joanxie
I don't think IPU can support 3-streaming from 1 CSI camera, but vpu can encode multiple streaming.
we have surround view solution, hope helpful for you. but this solution is for 4 camera.
<iMX6DQ MAX9286 MIPI CSI2 720P camera surround view solution for Linux BSP >.
