How to fully secure an IMX8M device
916 次查看
TomHarvey
Hi all,
I am currently trying to fully secure an IMX8M device. I have programmed the SRK_HASH and am currently able to perform a high assurance boot with a signed bootloader and image.
In the AN4581 it lists the following fuses that must be programmed to fully secure the device:
• SRK_LOCK: Lock for SRK_HASH[255:0] fuses.
• DIR_BT_DIS: Disable direct external memory boot.
• SJC_DISABLE: Disable the secure JTAG controller module.
• JTAG_SMODE: Set JTAG security mode to no debug mode 0x11.
• JTAG_HEO: Disallows HAB JTAG enabling.
• BOOT_CFG_LOCK: Lock on BOOT related fuses.
I have worked out the the word, bank and fuse values by reading IMX8MDQLQRM and IMX8MDQLQSRM for the SRK_LOCK, BOOT_CFG_LOCK and SEC_CONFIG: (Please let me know if these are correct).
SRK_LOCK
fuse prog 0 0 0x100
BOOT_CFG_LOCK
fuse prog 0 0 0xC
SEC_CONFIG
fuse prog 1 3 0x2000000
For DIR_BT_DIS the technical specification states that:
"The DIR_BT_DIS eFuse must be programmed prior to shipping
a device in a security enabled configuration. If the this eFuse is
not blown, the system is not secure."
So I assume that this does not need to be programmed.
For SJC_DISABLE and JTAG_SMODE I cannot find the mappings in the technical specification and have come across a forum post that details the following:
Fuse addrFuse nameNum bitsFuse functionSettingUsed by
0x470[21]SJC_DISABLE1Disable/Enable the Secure JTAG Controller module. This fuse is used to create highest JTAG security level, where JTAG is totally blocked.0 - Secure JTAG Controller is enabled
1 - Secure JTAG Controller is disabled
SJC
0x470[23:22]JTAG_SMODE[1:0]2JTAG Security Mode. Controls the security mode of the JTAG debug interface00 - JTAG enable mode
01 - Secure JTAG mode
11 - No debug mode
SJC
https://community.nxp.com/t5/i-MX-Processors/DIR-BT-DIS-and-others/m-p/1212354
And i can't see a mention of JTAG_HEO.
I would like to understand the following to fully secure the device:
  • Does DIR_BT_DIS need to be programmed? If so what values?
  • For SJC_DISABLE and JTAG_SMODE are the values shown in the table above 0x470[21] and 0x470[23:22] correct?
  • Do i need to program JTAG_HEO if so what is its fuse mapping?
  • Is there anything additional i need to program to fully secure the device. For instance do i need to program fuses such as FIELD_RETURN?
Please may someone send the the relevant information or documents detailing this.
Kind regards,
Tom
4 回复数
884 次查看
Harvey021
Will reply back to you in system email as some fuse information can't be discussed publicly.
Harvey
281 次查看
kirankumar007
I.MX8MP EVK JTAG Detection issue.
Default image eMMC booted stopped at Uboot using putty.
After uboot Read following data received in Putty Terminal,
0x470[21]  SJC_DISABLE  is =  0x1
0x470[23:22]  JTAG_SMODE[1:0][1:0] = 0x11
In data sheet
JTAG_SMODE[1:0] = 0x11 means [11 - No debug mode]
From these how to get back in to Debug JTAG mode????
Please guide us
869 次查看
emmanuel_madrigal
Hi Harvey,
Would it be possible for you to send me this information as well?
Emmanuel
835 次查看
Harvey021
Hi @emmanuel_madrigal
As some information is under NDA, suggest to raise a ticket with Confidential assistance
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2075305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%AE%8C%E5%85%A8%E4%BF%9D%E6%8A%A4%20IMX8M%20%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%AE%8C%E5%85%A8%E4%BF%9D%E6%8A%A4%20IMX8M%20%E8%AE%BE%E5%A4%87%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AF%B9SRK_HASH%E8%BF%9B%E8%A1%8C%E4%BA%86%E7%BC%96%E7%A8%8B%EF%BC%8C%E7%9B%AE%E5%89%8D%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E7%AD%BE%E5%90%8D%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E6%98%A0%E5%83%8F%E6%89%A7%E8%A1%8C%E9%AB%98%E5%BA%A6%E4%BF%9D%E8%AF%81%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%20AN4581%20%E4%B8%AD%EF%BC%8C%E5%AE%83%E5%88%97%E5%87%BA%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%BF%85%E9%A1%BB%E7%BB%8F%E8%BF%87%E7%BC%96%E7%A8%8B%E6%89%8D%E8%83%BD%E5%AE%8C%E5%85%A8%E4%BF%9D%E6%8A%A4%E8%AE%BE%E5%A4%87%E7%9A%84%E7%86%94%E4%B8%9D%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%E2%80%A2%20SRK_LOCK%EF%BC%9A%E9%94%81%E5%AE%9A%20SRK_HASH%20%5B255%3A0%5D%20%E7%86%94%E4%B8%9D%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20DIR_BT_DIS%EF%BC%9A%E7%A6%81%E7%94%A8%E7%9B%B4%E6%8E%A5%E5%A4%96%E9%83%A8%E5%AD%98%E5%82%A8%E5%99%A8%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3E-%20SJC_DISABLE%EF%BC%9A%E7%A6%81%E7%94%A8%E5%AE%89%E5%85%A8%20JTAG%20%E6%8E%A7%E5%88%B6%E5%99%A8%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20JTAG_SMODE%EF%BC%9A%E5%B0%86%20JTAG%20%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%97%A0%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%200x11%E3%80%82%3CBR%20%2F%3E-%20JTAG_HEO%EF%BC%9A%E7%A6%81%E6%AD%A2%E5%90%AF%E7%94%A8%20HAB%20JTAG%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20BOOT_CFG_LOCK%EF%BC%9A%E9%94%81%E5%AE%9A%E4%B8%8E%E5%90%AF%E5%8A%A8%E7%9B%B8%E5%85%B3%E7%9A%84%E7%86%94%E4%B8%9D%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E9%80%9A%E8%BF%87%E9%98%85%E8%AF%BB%20SRK_LOCK%E3%80%81BOOT_CFG_LOCK%3C%2FSTRONG%3E%20%E5%92%8C%3CSTRONG%3E%20S%20EC_CONFIG%3C%2FSTRONG%3E%20%E7%9A%84%20IMX8MDQLQRM%20%E5%92%8C%20IMX8MDQLQSRM%20%E8%AE%A1%E7%AE%97%E5%87%BA%E5%8D%95%E8%AF%8D%E3%80%81bank%20%E5%92%8C%E7%86%94%E4%B8%9D%20%E7%9A%84%E5%80%BC%EF%BC%9A%EF%BC%88%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E8%BF%99%E4%BA%9B%E5%80%BC%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3ESRK_LOCK%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BF%9D%E9%99%A9%E4%B8%9D%E6%8F%92%E5%A4%B4%200%200%200%20x100%3CSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%20BOOT_CFG_LOCK%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%86%94%E4%B8%9D%E6%8F%92%E5%A4%B4%200%200%200xC%3C%2FP%3E%3CP%3E%3CSTRONG%3ESEC_CONFIG%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%86%94%E4%B8%9D%E6%8F%92%E5%A4%B4%201%203%200x2000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%20%3CSTRONG%3EDIR_BT_DIS%3C%2FSTRONG%3E%EF%BC%8C%E6%8A%80%E6%9C%AF%E8%A7%84%E8%8C%83%E8%A7%84%E5%AE%9A%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%22%20%E5%9C%A8%E4%BB%A5%E5%90%AF%E7%94%A8%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E5%8F%91%E8%B4%A7%E8%AE%BE%E5%A4%87%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%AF%B9%20DIR_BT_DIS%20eFuse%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E8%AF%A5%E7%94%B5%E5%AD%90%E4%BF%9D%E9%99%A9%E4%B8%9D%3CBR%20%2F%3E%E6%B2%A1%E6%9C%89%E7%86%94%E6%96%AD%EF%BC%8C%E5%88%99%E7%B3%BB%E7%BB%9F%E4%B8%8D%E5%AE%89%E5%85%A8%E3%80%82%22%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%97%A0%E9%9C%80%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%3CSTRONG%3ESJC_DISABLE%20%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EJTAG_SMODE%20%3C%2FSTRONG%3E%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%8A%80%E6%9C%AF%E8%A7%84%E8%8C%83%E4%B8%AD%E6%89%BE%E5%88%B0%E7%9B%B8%E5%85%B3%E6%98%A0%E5%B0%84%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%BA%86%E4%B8%80%E7%AF%87%E5%B8%96%E5%AD%90%EF%BC%8C%E5%85%B6%E4%B8%AD%E8%AF%A6%E7%BB%86%E4%BB%8B%E7%BB%8D%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22101.45888594164455%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2212.234460849412807%25%22%20height%3D%2245px%22%3E%E7%86%94%E4%B8%9D%E5%9C%B0%E5%9D%80%3C%2FTD%3E%3CTD%20width%3D%2219.704710569486757%25%22%20height%3D%2245px%22%3E%E7%86%94%E6%96%AD%E5%99%A8%E5%90%8D%E7%A7%B0%3C%2FTD%3E%3CTD%20width%3D%227.737937140327583%25%22%20height%3D%2245px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%E4%BD%8D%E6%95%B0%3C%2FTD%3E%3CTD%20width%3D%2234.755415399141256%25%22%20height%3D%2245px%22%3E%E7%86%94%E4%B8%9D%E5%8A%9F%E8%83%BD%3C%2FTD%3E%3CTD%20width%3D%2230.405585250542117%25%22%20height%3D%2245px%22%3E%E8%AE%BE%E7%BD%AE%3C%2FTD%3E%3CTD%20width%3D%227.810320781032079%25%22%20height%3D%2245px%22%3E%E5%B7%B2%E4%BD%BF%E7%94%A8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2212.234460849412807%25%22%20height%3D%22110px%22%3E0x470%5B21%5D%3C%2FTD%3E%3CTD%20width%3D%2219.704710569486757%25%22%20height%3D%22110px%22%3ESJC_DISABLE%3C%2FTD%3E%3CTD%20width%3D%227.737937140327583%25%22%20height%3D%22110px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E1%3C%2FTD%3E%3CTD%20width%3D%2234.755415399141256%25%22%20height%3D%22110px%22%3E%E7%A6%81%E7%94%A8%2F%E5%90%AF%E7%94%A8%E5%AE%89%E5%85%A8%20JTAG%20%E6%8E%A7%E5%88%B6%E5%99%A8%E6%A8%A1%E5%9D%97%E3%80%82%E8%AF%A5%E7%86%94%E4%B8%9D%E7%94%A8%E4%BA%8E%E5%88%9B%E5%BB%BA%E6%9C%80%E9%AB%98%E7%9A%84%20JTAG%20%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E7%BA%A7%E5%88%AB%EF%BC%8C%E5%85%B6%E4%B8%AD%20JTAG%20%E8%A2%AB%E5%AE%8C%E5%85%A8%E5%B1%8F%E8%94%BD%E3%80%82%3C%2FTD%3E%3CTD%20width%3D%2230.405585250542117%25%22%20height%3D%22110px%22%3E0%20-%20%E5%90%AF%E7%94%A8%E5%AE%89%E5%85%A8%20JTAG%20%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3E1%20-%20%E7%A6%81%E7%94%A8%E5%AE%89%E5%85%A8%20JTAG%20%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FTD%3E%3CTD%20width%3D%227.810320781032079%25%22%20height%3D%22110px%22%3ESJC%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2212.234460849412807%25%22%20height%3D%22110px%22%3E0x470%5B23%3A22%5D%3C%2FTD%3E%3CTD%20width%3D%2219.704710569486757%25%22%20height%3D%22110px%22%3Ejtag_smode%5B1%3A0%5D%20(%E6%A0%87%E8%AE%B0%E6%A8%A1%E5%BC%8F)%3C%2FTD%3E%3CTD%20width%3D%227.737937140327583%25%22%20height%3D%22110px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%3CTD%20width%3D%2234.755415399141256%25%22%20height%3D%22110px%22%3EJTAG%20%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%E3%80%82%E6%8E%A7%E5%88%B6%20JTAG%20%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%9A%84%20%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%20%E6%A8%A1%E5%BC%8F%3C%2FTD%3E%3CTD%20width%3D%2230.405585250542117%25%22%20height%3D%22110px%22%3E00%20-%20%E5%90%AF%E7%94%A8%20JTAG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E01%20-%20%E5%AE%89%E5%85%A8%20JTAG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E11%20-%20%E6%97%A0%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%3C%2FTD%3E%3CTD%20width%3D%227.810320781032079%25%22%20height%3D%22110px%22%3ESJC%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FDIR-BT-DIS-and-others%2Fm-p%2F1212354%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FDIR-BT-DIS-and-others%2Fm-p%2F1212354%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%80%8C%E4%B8%94%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%3CSTRONG%3EJTAG_HEO%3C%2FSTRONG%3E%E7%9A%84%E6%8F%90%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%AE%8C%E5%85%A8%E4%BF%9D%E6%8A%A4%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%88%91%E6%83%B3%E4%BA%86%E8%A7%A3%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EDIR_BT_DIS%20%3C%2FSTRONG%3E%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E7%BC%96%E7%A8%8B%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%98%AF%E4%BB%80%E4%B9%88%E5%80%BC%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%AF%B9%E4%BA%8E%3CSTRONG%3ESJC_DISABLE%20%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EJTAG_SMODE%20%3C%2FSTRONG%3E%EF%BC%8C%E4%B8%8A%E8%A1%A8%E4%B8%AD%E7%9A%84%3CSTRONG%3E0x470%5B21%5D%20%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3E0x470%5B23%3A22%5D%20%3C%2FSTRONG%3E%E5%80%BC%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E7%BC%96%E7%A8%8B%20%3CSTRONG%3EJTAG_HEO%20%E5%90%97%EF%BC%9F%E5%AE%83%E7%9A%84%3C%2FSTRONG%3E%E7%86%94%E4%B8%9D%E6%98%A0%E5%B0%84%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E7%BC%96%E7%A8%8B%E4%BB%80%E4%B9%88%E6%9D%A5%E5%AE%8C%E5%85%A8%E4%BF%9D%E6%8A%A4%E8%AE%BE%E5%A4%87%E5%90%97%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%AF%B9%E8%AF%B8%E5%A6%82%20%3CSTRONG%3EFIEL%3C%2FSTRONG%3E%20D_RETURN%20%E4%B9%8B%E7%B1%BB%E7%9A%84%E7%86%94%E4%B8%9D%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E5%90%97%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%AF%B7%E9%97%AE%E8%B0%81%E8%83%BD%E6%8F%90%E4%BE%9B%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%E6%88%96%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3ETom%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20fully%20secure%20an%20IMX8M%20device%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI.MX8MP%20EVK%20JTAG%20%E6%A3%80%E6%B5%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20putty%20%E5%9C%A8%20Uboot%20%E5%90%AF%E5%8A%A8%E6%97%B6%E5%81%9C%E6%AD%A2%E4%BA%86%E9%BB%98%E8%AE%A4%E6%98%A0%E5%83%8F%20eMMC%E3%80%82%20%3C%2FP%3E%3CP%3Euboot%20%E5%90%8E%20%E5%9C%A8%20Putty%20%E7%BB%88%E7%AB%AF%E4%B8%AD%E8%AF%BB%E5%8F%96%E6%94%B6%E5%88%B0%E7%9A%84%E4%BB%A5%E4%B8%8B%E6%95%B0%E6%8D%AE%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kirankumar007_1-1761205384356.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kirankumar007_1-1761205384356.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362265i4A918DA2B71E16EF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kirankumar007_1-1761205384356.png%22%20alt%3D%22kirankumar007_1-1761205384356.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0x470%5B21%5D%20SJC_DISABLE%20%3D%200x1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0x470%5B23%3A22%5D%20JTAG_SMODE%5B1%3A0%5D%5B1%3A0%5D%20%3D%200x11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EJTAG_SMODE%5B1%3A0%5D%20%3D%200x11%20%E8%A1%A8%E7%A4%BA%20%5B11%20-%20%E6%97%A0%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%BD%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E4%BD%95%E9%87%8D%E6%96%B0%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%20JTAG%20%E6%A8%A1%E5%BC%8F%3F%3F%3F%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E4%BB%AC%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20fully%20secure%20an%20IMX8M%20device%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248557%22%20target%3D%22_blank%22%3E%40emmanuel_madrigal%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%A4%84%E4%BA%8E%E4%BF%9D%E5%AF%86%E5%8D%8F%E8%AE%AE%E4%B9%8B%E4%B8%8B%EF%BC%8C%E5%BB%BA%E8%AE%AE%E5%90%91%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsupport%3ASUPPORTHOME%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%9C%BA%E5%AF%86%E5%8D%8F%E5%8A%A9%E9%83%A8%E9%97%A8%3C%2FA%3E%E6%8F%90%E5%87%BA%E6%8A%95%E8%AF%89%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2077579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20fully%20secure%20an%20IMX8M%20device%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2077579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E7%BB%B4%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%86%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E4%B9%9F%E5%8F%91%E7%BB%99%E6%88%91%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E7%BA%BD%E5%9F%83%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2076693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20fully%20secure%20an%20IMX8M%20device%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2076693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E7%86%94%E4%B8%9D%E4%BF%A1%E6%81%AF%E6%97%A0%E6%B3%95%E5%85%AC%E5%BC%80%E8%AE%A8%E8%AE%BA%EF%BC%8C%E5%B0%86%E9%80%9A%E8%BF%87%E7%B3%BB%E7%BB%9F%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E5%9B%9E%E5%A4%8D%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
