How to flash linux image on i.MX7 Board from Google Kit
1,770件の閲覧回数
kamilpacak
Hi! I want to flash ubuntu (or another OS by linux) on i.MX7 Board. I'm green in this things, and need some tutorials or instructions how to do it. Best Regards.
ラベル(2)
タグ(4)
1,598件の閲覧回数
Carlos_Musich
Hi Kamil,
NXP provides BSPs with different kernel versions to build a linux image for NXP boards. Please go to www.nxp.com/imx7 and select the derivative you are using. Then go to DOCUMENTATION tab > Supporting Information and you can select the BSP with the kernel you like. Here you will find instructions to build a Linux Image for your board.
Carlos
NXP Technical Support
