Hi @Eddy1,
Thank you for contacting NXP Support.
You can try editing Weston backend that could cause the issue with the coordinates.
Please try with the following solution:
On weston.ini file use kiosk-shell to replace desktop-shell set by default.
$ vi /etc/xdg/weston/weston.ini
[core]
shell=kiosk-shell.so
$systemctl start weston
$./play
If this solution doesn't work, please describe in more detail your issue and your test results.
Have a great day!
