How to enable the bluetooh for iMX8MP
Rayn_Jang
I am trying to operate the bluetooth module on the imx8mp board.
Bluetooth module is Laird BT830.
The Android BSP version is Android 11.0.0_2.6.0.
Rayn_Jang
Can't port other BT modules besides 88W8997?
Does the BT HAL support connecting other Bluetooth modules?
joanxie
yes you can use other module, I just mention the current bsp support this as default, for your own BT, you just need UART port and PCM port (if need HFP)
Rayn_Jang
I need to use "bccmd" to initialize the bt830 module.
See below for information on using "bccmd".
bccmd is not available for BSP.
There is no bluez tool in the external directory.
I tried to port the bluez tool from outside, but I couldn't port it because of numerous errors.
Can you help me to use bccmd?
joanxie
it seems current bsp doesn't support this tool
joanxie
for android 11.0.0_2.6.0, which supports NXP 88W8997 for i.MX 8M Plus EVK and i.MX 8MQuad EVK Rev. A board
