Solved! Go to Solution.
Hi viking_yuan
one can check if usb mode is configured properly in dts using
sect.4.9.9 Changing the Controller Operation Mode i.MX Linux Reference Manual
Thanks igor!
So, if I want to use both device and host mode, I should configure it as below, correct?
dr_mode = "otg" /* Set controller as otg mode */
right.
Hi viking_yuan
