How to enable screen time out while a qt app is running on imx6slevk?
1,650件の閲覧回数
sujay1
Contributor V
I'm using an imx6slevk board with yocto BSP
I use linuxfb as the display driver and run a qt app (rastor window: prints a message on the lcd console)
I observed that when the app is running the screen doesn't timeout after 10 minutes of staying idle
How can I change this?
I tried modifying /drivers/tty/vt/vt.c file but the screen doesn't turn off
I also observed that the weston feature is not supported in linuxfb
does anyone have an idea how to implement this without weston?
ラベル(3)
2 返答(返信)
1,571件の閲覧回数
Bio_TICFSL
Hello Sujay,
Appears this is not a weston issue, it looks more like application side.
1,571件の閲覧回数
sujay1
Contributor V
Any idea how we can implement this?
Thanks in advance
