How to enable WiFi on i.MX8ULP using init scripts to avoid configuring WiFi on each boot?
2,472件の閲覧回数
Namitha_zcs
I have enbaled wifi on IMX8ULP to connect to an AP in station mode uisng the following commands from  the IMX linux reference manual .
modprobe moal mod_para=nxp/wifi_mod_para.conf
head -n 4 /etc/wpa_supplicant.conf > /etc/wpa_supplicant.conf.tmp
wpa_passphrase ssid password >> /etc/wpa_supplicant.conf.tmp
mv /etc/wpa_supplicant.conf /etc/wpa_supplicant.conf.bak
mv /etc/wpa_supplicant.conf.tmp /etc/wpa_supplicant.conf
wpa_supplicant -B -i mlan0 -c /etc/wpa_supplicant.conf -D nl80211
However,the configuration resets in every boot .How can I  enable WiFi uisng init scripts so that it starts automatically in boot? .
2,442件の閲覧回数
Chavira
HI @Namitha_zcs!
Thank you for contacting NXP Support!
The definitive solution is create a custom startup script as a service:
Step 1: Go to etc/systemd/system
cd /etc/systemd/system
Step 2: In this directory create a new file with the name of your preference but the
extension must be .service.
The file must contain:
[Unit]
Description=”Wifi Start”
[Service]
ExecStart=sudo modprobe moal mod_para=nxp/wifi_mod_para.conf
[Install]
WantedBy=multi-user.target
Now save the file, in my case the name was wifi_start.service.
Step 3: Now we need to enable the script in the startup/boot sequence following the
command:
sudo systemctl enable wifi_start.service
Finally, each time you boot your board, the WIFI module will initialize automatically.
4 返答(返信)
2,235件の閲覧回数
atbkoad
This help me a lot on my recent project with iMX8ULP. I will apply it to my device later for testing.
2,443件の閲覧回数
Chavira
HI @Namitha_zcs!
[Unit]
[Service]
[Install]
command:
2,421件の閲覧回数
Namitha_zcs
Thankyou for your response.
2,463件の閲覧回数
Joel742Bushong
Hello!
To enable WiFi on your IMX8ULP automatically at boot, create a custom startup script as a service. Create a file in /etc/systemd/system (e.g., wifi_start.service) with the necessary configuration, and then run sudo systemctl enable wifi_start.service to add it to the startup sequence. This will ensure the WiFi module initializes each time you boot.
%3CLINGO-SUB%20id%3D%22lingo-sub-2036010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Einit%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6i.MX8ULP%E3%81%A7WiFi%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9F%E3%81%B3%E3%81%ABWiFi%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIMX%20Linux%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7AP%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81IMX8ULP%E3%81%A7wifi%E3%82%92%E3%82%A8%E3%83%B3%E3%83%90%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Emodprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%3CBR%20%2F%3Ehead%20-n%204%20%2Fetc%2Fwpa_supplicant.conf%20%26gt%3B%20%2Fetc%2Fwpa_supplicant.conf.tmp%3CBR%20%2F%3Ewpa_passphrase%20ssid%20%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%20%26gt%3B%26gt%3B%20%2Fetc%2Fwpa_supplicant.conf.tmp%3CBR%20%2F%3Emv%20%2Fetc%2Fwpa_supplicant.conf%20%2Fetc%2Fwpa_supplicant.conf.bak%3CBR%20%2F%3Emv%20%2Fetc%2Fwpa_supplicant.conf.tmp%20%2Fetc%2Fwpa_supplicant.conf%3CBR%20%2F%3Ewpa_supplicant%20-B%20-i%20mlan0%20-c%20%2Fetc%2Fwpa_supplicant.conf%20-D%20nl80211%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%81%94%E3%81%A8%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82WiFi%20uisng%20init%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%20.%20.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2043075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ainit%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6i.MX8ULP%E3%81%A7WiFi%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9F%E3%81%B3%E3%81%ABWiFi%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2043075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81iMX8ULP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%9C%80%E8%BF%91%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E5%A4%A7%E3%81%84%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%BE%8C%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ainit%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6i.MX8ULP%E3%81%A7WiFi%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9F%E3%81%B3%E3%81%ABWiFi%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ainit%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6i.MX8ULP%E3%81%A7WiFi%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9F%E3%81%B3%E3%81%ABWiFi%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%ABIMX8ULP%E3%81%A7WiFi%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%A7%20%2Fetc%2Fsystemd%2Fsystem%20%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(%E4%BE%8B%3A%20wifi_start.service)%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81sudo%20systemctl%20enable%20wifi_start.service%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%ABWiFi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
