How to enable Wi-Fi Direct Option in Android 7.1.1_1.0.0 ?
4,069 次查看
ThanarajS
Hi All,
   Previously I had worked on KK, LLP, MM bring up on Wi-Fi/Hostapd/BT.
   Currenty I am working on Wi-Fi Direct Implementation with Our Wi-Fi Chip in Android 7.1.1_1.0.0.
   1. Can anyone give Basic Information to start Wi-Fi Direct in Android 7  ?...[Where i need to port Wi-Fi Direct related Info to enable Option and see scan results.].
   2. How to handle both Normal Wi-Fi and  Wi-Fi Direct ?
Thanks in advance!!
Raj.
Thanaraj Subramani
标签 (3)
1 回复
1,263 次查看
weidong_sun
                The WiFI Direct is enabled by default in n7.1.1 release for BCM4339 WiFi chip.
                You can find it in Settings->WiFi->More.
TIC weidong
