I am trying to integrate the TC358743 hdmi to mipi csi driver in my build with nitrogen6x board.
But not able to find the dtsi configuration for this driver. Driver is available on:
Below is the tree structure of this driver:
tc358743@0f {
compatible = "toshiba,tc358743";
reg = <0x0f>;
clocks = <&hdmi_osc>;
clock-names = "refclk";
reset-gpios = <&gpio6 9 GPIO_ACTIVE_LOW>;
interrupt-parent = <&gpio2>;
interrupts = <5 IRQ_TYPE_LEVEL_HIGH>;
port {
tc358743_out: endpoint {
remote-endpoint = <&mipi_csi2_in>;
data-lanes = <1 2 3 4>;
clock-lanes = <0>;
clock-noncontinuous;
link-frequencies = /bits/ 64 <297000000>;
Can you please help me out feel the correct value of this tree structure.
Sunil
解決済! 解決策の投稿を見る。
Hi Sunil
seems below is TC358743 dtsi :
Hi Sunil
