How to enable OVM6211 camera
2,756 次查看
pradip7744
How to enable OVM6211 camera module with IMX8M Plus series processor
6 回复数
2,733 次查看
pradip7744
https://github.com/nxp-imx-support/imx8mp-imx219-sensor-enablement
this link not able to open can you please check and also if we will use serial camera interface SCCB communication then the same things will be working same driver ?
2,727 次查看
joanxie
because of license issue, this software package is removed temporarily, you also can refer to the document, for SCCB, current bsp couldn't support it as default, you need change the I2C driver to support such camera
2,745 次查看
joanxie
OVM6211 isn't supported in current bsp as default, so you need offer more detailed information about this camera, what format do you use? raw data or YUV data? and what resolution do you need support?
2,737 次查看
pradip7744
Actually we are going to use multiple camera using SCCB communication protocol and also its datasheet is been attached here.
The camera is 8 to 10 bit ROW data output formats
2,733 次查看
joanxie
I think you mean 8BITS/10BITS raw data, right? for raw data support on imx8mp, I suggest that you can use ISP for capture, for ISP porting, you can refer to the IMX219 camera porting as below
for ISP document, you also can find them from nxp official website as below
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
2,728 次查看
pradip7744
this link is not able to open can you please check and share again.
