How to enable MINI-PCIe slot support
4,614 次查看
venkatesh_dyaga
Hi all,
We use IMX6SLEVK. Linux Host driver built with fsl-community-bsp. Distro is framebuffer. We want to use PCIe slot and tried different PCI slot in kernel configuration combinations.
lspci is not showing any devices.
Please tell us the required kernel config.
标记 (1)
8 回复数
4,381 次查看
igorpadykov
Hi venkatesh
for kernel configurations one can look on
i.MX6Q PCIe EP/RC Validation System
and linux documentation (Linux Manual, PCIe Chapter) on i.MX Software | NXP
may be useful to check
IMX6Q: Linux boot halts at PCIe config space read
4,380 次查看
venkatesh_dyaga
Hi igor,
I followed the links above and changed configurations but it is not detecting any.
Please find attachments and tell us issue
kernel dmesg prints file imx6slevk_kernel_log
kernel configuration file(.config) imx6slevk_kernel_config
4,380 次查看
igorpadykov
Hi venkatesh
fsl-community-bsp is not supported by nxp, please try nxp official linux
from source.codeaurora.org/external/imx/linux-imx repository:
linux-imx - i.MX Linux kernel
Linux Documentation
https://www.nxp.com/design/i.mx-developer-resources/i.mx-software-and-development-tool:IMX-SW
4,380 次查看
venkatesh_dyaga
Hi igor,
I have attached the logs of yocto build with imx-yocto-bsp only in the previous reply and i forgot to mention that , Please look into that and let me know.
venkatesh
4,380 次查看
igorpadykov
imx6slevk_kernel_log.zip log is empty. Please rebuild all from scratch
and attach full log, including uboot and kernel, without cuttings.
4,380 次查看
venkatesh_dyaga
I am so sorry that I wasted your time. Please find attached kernel boot prints in imx6slevk_kernel_dmesg. Please see and let us know the configuration(imx6slevk_kernel_config) issue.
4,380 次查看
igorpadykov
Hi venkatesh
I am very sorry that first did not notice that, but i.MX6SL has not PCIe module.
EVK has MINI PCI EXPRESS connector but only usb signals are used for
attaching modem. May be useful to look at i.MX comparison table
https://www.nxp.com/docs/en/brochure/FLYRIMXPRDCMPR.pdf
4,380 次查看
venkatesh_dyaga
Yes. We are using Qualcomm card. It is currently inserted into MINI-PCIe slot.
Unfortunately we don't have any other card.
