How to enable M.2 key-e on imx8mq evk board
prasanthk
I am using Imx8mq evk board with 5.10 kernel(yocto hardknott). I want to to enable M.2 connector with key-e compatible. Please suggest the changes in device tree.
Prasanth
prasanthk
How to use UART on M.2 connector?
Zhiming_Liu
prasanthk
Thank you for quick response, I changed the status disabled to okay in dts, pcie is detecting now, but uart lines are not working on M.2 card and Bluetooth reset(GPIO3_5-> gpio101) its always high. Please share the inputs on M.2 uart issue.
Zhiming_Liu
The uart and reset gpio should be controlled by driver, like NXP M.2 BT driver.
